I need help with creating an airfoil with .dmx file whenever I import it it throws an error.
Everytime i try to insert a .dmx file for the airfoild for the planes wing. I get this error message "The DXF/DWG imported with the following error:
- Could not import unrecognized entity." DOES ANYONE know how to fix this https://cad.onshape.com/documents/1186b7ba783480919ff0bbd0/w/ccd66d15efeebb87b376e1b6/e/098dad38282d4e9186efc4dc
  • martin_kopplowmartin_kopplow Member Posts: 1,485 PRO
    You could import a formatted text file with point coordintes and build a spline on it. There is an older feature script called JSpline to do this, or another one that takes CSV files and is called CSVxyz1. It may be easier to fiddle with bulk text re-formatting than with DXF file import.
