what is the best alternative to boolean controlled geometry in master sketch
First let me explain what I mean by "boolean controlled geometry in master sketch". Would like to do something that I don't think is possible so I am seeking alternative options that might make more sense
context
Here is an example of what I would like to do
  • High level, say I'm trying to create a variable driven model of a wood framed wall (studs and such)
  • I'd like to have a master sketch that just defines some basic measurements. Just wall height / length, window placement and window dimensions. a rectangle with some smaller rectangles inside it basically
  • I'd like all this to be defined using variables. Just update the variables and get a new wall layout sketch
  • I'd then use the dimensions from that master sketch to place parts (studs) in an assembly using linear patterns (among other things)
So far all well supported as I understand it
The problem
The problem is, I'd like to be able to support a variable number of windows. IE I'd like some of the smaller rectangles to either exist or not exist according to how I set the variables. Let's say my model could support 0 windows up through 4 windows (arbitrary fairly low upper bound to keep things simple). I'd like to be able to control all this using variables in a master sketch and have a downstream wall assembly update with the correct framing.
my initial thought was to have as many variables as I wanted windows to support. So I'd have something like
window_1_exists = true, window_1_height=whatever, (and then the rest of the variables to define window 1)
and then I would repeat this for window_2, window_3, up to however many windows I want to support
This is not possible however. I cannot define a boolean variable and use it to "add or remove" geometry (in this case just a rectangle for a window) from my master sketch
Possible solution
it seems that boolean including or removing of things does exist at the assembly level via assembly configuration checkboxes. It occurs to me that maybe there could be someway to use an abstract "master assembly" to roughly define the wall dimensions and window positions instead of a "master sketch" and then derive my completed assembly from that "master assembly"
I'm pretty new to onshape though and it would not surprise me if there is some reason that is quite a bad idea so I thought I'd ask here and see if anyone had any input before I invest too much time down that path. Thank you in advance for any input
