Feature script extrude offset issue
Hi,
I would like to know how I can make an extrude with an offset within a feature script. The link below points to an example project with a failed offset extrude.
The parameter "hasOffset" is set to true and the "offsetDistance" is set to 5 * millimeter. The feature script generates without error but also without offset.
https://cad.onshape.com/documents/d31a2b5fce1853fef7e29e84/w/f78234041a509038f0f8f16f/e/bd304393ab505e0f1d7fb897?renderMode=0&uiState=690af8abf56884b742d62c9d
