Loft "all guides should intersect with profile boundary
I am designing a boat hull, it has a smooth curve (created with a spline) at the bottom and a sharp corner at the top.
I want to loft between the 3 faces i have created but the two upper line to not intersect with the opposite far side, is there a way to resolve this?
as you can see some funky geometry going on at the top there, when it should just be two straight lines and a hard curve
https://cad.onshape.com/documents/965d00636b4cff3c831b75f4/w/a429fce9c34442e3707ebcc9/e/98777789e5ab75d5236c4a8c?renderMode=0&uiState=6926f3d3d4504ac113985b3f
