setProperty for appearance
graham_lock
Member Posts: 277 PRO
Hi all,
I'm trying to set colours of some faces but it's not working.
The target faces already have an appearance set via the UI.
My code is of this form:
var theColor is Color = color(1, 0, 1);
setProperty(context, {
"entities" : facesToColor,
"propertyType" : PropertyType.APPEARANCE,
"value" : theColor
Should the FS code override the UI appearances? If not is there a way to reset the UI settings such that the FS will work?
Thank you.
Right-click the part, select Properties, click Reset All.
Yeah, that's a weird one. Happens to me sometimes, too. I just type something random into the Description, hit Apply, then the Reset button comes back to life.
1 -
That got it!
Thank you.
