Adding an offset lip along the shell
arda_asik
arda_asik Member Posts: 2 EDU
Hi I am trying to add a lip to the case of a macro pad thing that I am trying to build. Basically it has 3 parts a case, midplate that will be sandwiched between and a bottom plate. I am having problems creating the "lip" that midplate will sit on.
https://cad.onshape.com/documents/5428a4782e734fd968f48982/w/da8ddffe4c4c60b884fa5a34/e/c258022a1ead55f039eb4313?renderMode=0&uiState=694bf8f5f8ddf161493ed6ee
Here is the case from the bottom,
I want to add a something like a second shell a lip that will support the middle plate, which will hold the rotary encoders and switches, something like this,
The face of the case has a slight angle, and I want the midplate to be parallel to it, so I try to extrude with direction however I get gaps like this,
What would be the best way to achive this? In the I want a midplate parallel to the face of the case that will sit in the lip of the case,
That will have a 1mm offset to the body all around. Thanks in advance!
BR,
-Arda.
