Sweep on a conical spiral
mario_zadra
Member Posts: 5 ✭
Hello,
This problem is driving me crazy.
I would simply like to sweep a rectangle along a conical spiral and at the same time rotate it 90°.
If I use the sweep command, I can't control the amount of rotation (it can be 0° if I use lock profile direction, but it is not
what I want) ; if I use the loft command, the dimensions of the rectangle change along the path.
What can i do?
Than you very much
Mario
https://cad.onshape.com/documents/6f8c1deef0bc6e21c9efac94/w/3fd6b2402f5a89ca6d428fa5/e/6b76f7f2033a6836567f5ac3?renderMode=0&uiState=694c01dd26f810cdc934cffb
john_lopez363
Member Posts: 143 ✭✭✭
@mario_zadra … you need to use Loft…not Sweep.
The trick is to change the point where your Loft Profile intersects the spiral.
1. add a point on the bottom line at the mid-point for both profile sketches.
2. use the pierce constraint from that point to the spiral4
Have a look into tweep feature by Derek.
Thank you very much…it works perfectly!!!!!
Thank you very much, it works!!!
