Introduction to the Onshape API training course
james_anderson507
Member Posts: 6 ✭
section 03.Post Requests
exercise: Executing a POST Request slide 3 of 7
when I click execute I receive server response code 409 instead of 200
Make sure you are logged into Onshape in another tab in your browser.
Make sure you are using the correct endpoint:
https://cad.onshape.com/glassworks/explorer/#/Document/copyWorkspaceMake sure you have the correct request body.
{ "isPublic": false, "newName": "Mailman Robot", "ownerId": "xxxxxxxxxxxxxx" }0 -
slide 3 points to the following:
POST/documents/{did}/workspaces/{wid}/copy0
