Introduction to the Onshape API training course
section 03.Post Requests
exercise: Executing a POST Request slide 3 of 7
when I click execute I receive server response code 409 instead of 200
  • Matt_Shields
    Matt_Shields Member, Onshape Employees Posts: 1,001 PRO
    Make sure you are logged into Onshape in another tab in your browser.
    Make sure you are using the correct endpoint:
    https://cad.onshape.com/glassworks/explorer/#/Document/copyWorkspace
    Make sure you have the correct request body.
         "isPublic": false,
         "newName": "Mailman Robot",
         "ownerId": "xxxxxxxxxxxxxx"
  • james_anderson507
    james_anderson507 Member Posts: 6 ✭
    slide 3 points to the following:
    POST
    /documents/{did}/workspaces/{wid}/copy
