I'm trying to create "spikes" on the top of my dirtbike footpeg sketch.
Hi there,
I'm very new to both drawing and onshape, in fact it's the first time I'm trying to create something.
I'm trying to create some dirtbike footpegs and I want to add spikes to the top similar to the S3 punk model. Here's an image for context:
Here is what I've created so far:
https://cad.onshape.com/documents/1461d04af5810264234f653f/w/5baeef2cd0b3c7d7b7b9ee2f/e/99c41f9ba880d084fca52187?renderMode=0&uiState=6977ae1b669339e4addf0b79
Can someone please help me with this?
Thanks in advance!
This may help to get started with the curve pattern using an extrude remove for the teeth.
Hi!
I have no access to your sketch, if you could please grant it.
Thanks!0 -
Here's my attempt using @glen_dewsbury's suggestion - although I used an elliptical path which didn't turn out symmetrical for some reason, so I ended up doing half, then mirroring.
Unemployed Onshaper- Operating on European time - More of me here ➤➤ https://linktr.ee/Liam.G0 -
Here is a sample to clean up some small things using like one sketch for main body instead of 2 and two extrudes. Assemble avoids duplicate parts in the feature tree with cleaner updates. Feature tree is down from 24 items to 14. Some time in the help center can't hurt.
