sheet metal bracket with flanges for welding
WJT
WJT Member Posts: 9 PRO
Looking for a little help from the sheet metal experts. I want the flange joints to meet when the bend is made but I can't seem to achieve this effect. The intent is to form the 4 flanges, bend the part, then weld the joint where the flange faces meet (blue arrow). The 'hole" at the corner will remain, so the protruding material (red arrow) needs to go away.
