Control hide and show body when comparing revisions
guy_rogel
Member, User Group Leader Posts: 98 PRO
I want to compare 2 versions of the same part studio to check what parts have changed.
But i can not find the way to hide and show a specific body at both of the versions.
this makes comparing very hard
Am I missing anything ?
romeograham
Member, csevp Posts: 757 PRO
If you move the slider above the model to the right, you'll see the bodies for V1, and be able to control their visibility in a similar way. With the slider in the middle, you'll be able to see the changes more easily, too.5
But can you do it for both V2 and V1 . I was only able to hide and show bodies in V2 but could not do the same on V1.
Is it possible ?
I completely agree!! In my case it makes the compare tool completely useless because I can't hide certain part! Please make a fix!!!
Yep, not sure if that's a regression and it used to work but currently you can only hide things when the slider is on the left and have no control over the "red" version visibility.
I want to revive this thread: hiding parts from both versions is still not possible and really downgrades the otherwise amazing compare feature.
