No border or geometry in new drawing
ray_h891
ray_h891 Member Posts: 4 EDU
My attempts to create a drawing from a part result in a blank screen. New drawing tab is created but there's no geometry or drawing border.
Result is the same whether I try to create 4-view drawing, or creating a blank drawing then inserting the desired view.
In the tree I can look at Sheet 1 properties. Format is "Custom" and seems to be pointing to no drawing template.
Are the public drawing templates referred to in the Onshape Help topic "Creating a Drawing" not available in the Student edition? Any other ideas on how to fix this?
  • MichaelPascoe
    edited March 6
    Try using Onshape's public drawing templates when creating a drawing:
  • ray_h891
    Those are the templates I'm trying to use. No border or geometry appears, just "Sheet 1" at the upper left of the screen.
  • ray_h891
    Found the solution with help from Onshape support.
    Chrome flags —> ANGLE graphics backend —> change D3D9 to D3D11
    Drawings appear normally.
