imported a file
robert_provostrobert_provost Member Posts: 2 PRO
i imported my file and nothing will let me fill or add extrude etc. i have been trying to figure out why i cant fix it so i can fill in fo i can print it what am i doing wrong.????
  • robert_scott_jr_robert_scott_jr_ Member Posts: 825 ✭✭✭
    Robert, do you mean that you imported a file into your document? If so, what type of file did you import? - Scotty
  • MorikaiMorikai Member Posts: 2 EDU
    It depends on what kind of file you imported. I'm just now figuring out how to import the files correctly so they don't turn into mixed models (which is likely what happened to you).
  • jim_zamecnikjim_zamecnik Member Posts: 101 ✭✭
    I've found that imported .dxf files can be challenging to close and constrain. Zoom way in on the mating points and make sure they're actually mated.
