Use face in assembly to slice multiple parts
Hello,
I want to use the face of Part 21 to slice off the corner where parts 1,4, and 20 meet. The parts are not arranged in relative position in my Part Studio, only in the Assembly… help!
Project: https://cad.onshape.com/documents/907d687903fd2d59f848d84b/w/4379adabfa341a8b79c3676e/e/2bfe09ba04fb1c9da9ccb6f1?renderMode=0&uiState=69bc28432bc819a81647f048Error
Untitled Image
  • eric_pesty
    The whole point of designing a bunch of parts in a single part studio is to model them in the correct location! So that is the correct way to solve your issue…
    You could probably use "in-context" editing but since you put all the parts on top of each other in as single part studio you will have to create a separate context for each of the parts and it's just going to be really messy (wouldn't be as bad with each part in a separate studio).
  • SMURFCAD
    SMURFCAD Member Posts: 87 ✭✭
    Hi Nicholas,
    Not trying to be a jerk, but, you are using the tool completely wrong. You should have created the "assembly" in a single Part Studio. This would allow you to easily modify parts based on how they fit together.
    If you are going to use Onshape on a continuing basis, there is some excellent free training available direct from Onshape.
    So, are you defining the sketches from a drawing, or measuring off parts? I don't see how else you could have created this. Your Part Studio should never look like this. The "Part Studio" is really a modeling space where assemblies can and usally should be created. Particularly if the parts are static relative to each other like your bumper.
  • nicholas_morris261
    nicholas_morris261 Member Posts: 7 ✭
    Thank you for the feedback! Yes, I'm just learning and the biggest challenge is understanding proper workflow! I built my parts from measuring real-life examples. In the part studio I was having issues with my sketches not being fully defined if they did not include a known point (the origin). My solution was to start at the origin for all my sketches, but doing it that way all of my parts overlap in the part studio. What is the proper way to do build fully-defined parts and toe define their positions in Part Studio?
  • SMURFCAD
    I created two of your parts in the Part Studio, using two different methods.
    First method: create a Mate connector at a logical location (where two edged line up for example). Then when you create a sketch, select the Make connector as your sketch plane. Use the Mate connector as your origin to dimension to.
    Second method: select geometry from the baseplate to use as your sketch plane. Then either align or dimension from your sketch to geometry on the baseplate to locate the sketch in the final two dimensions.
    Use below as a reference:
    https://cad.onshape.com/documents/475ca97e22883e396a643c31/w/c817faa4d1dac8ee8e088fea/e/fe41d130d420fe1b93edd951?renderMode=0&uiState=69bf1d772cf966b46f9af0a9
    Thank you for your help, @SMURFCAD!
    I think I understand your first method - defining my own mate connector to define the plane and origin for a new sketch.
    Your second method is a little unclear as described, but it's hard to tell rather than to show things like this.
    I see how you used three points on the model to create the plane for Bottom Triangle. How did you created the final point selected below? Was it done using the 'Pierce' constraint in combination with the edge of the Bottom Plate?
  • SMURFCAD
    The sketch used Intersection and select the faces of the parts that are being cut. You could use pierce as well.
