Can't select edges with tool, only vertices
theo_moore_calters
theo_moore_calters Member Posts: 4 ✭
edited March 22 in Community Support
Fresh sketch in part studio, no matter the shape; rectangle, multiple lines, polygon, none of my tools can select edges. Even if I right click and use the custom selection, it only registers the edges if I then drag a box around all the edges I want, which surely is not the intended way of doing things, right? (Because I cant drag and select entities when using a tool either way)
Is there some setting I have accidentally toggled that's causing this?
