Can't select edges with tool, only vertices
theo_moore_calters
Member Posts: 4 ✭
Fresh sketch in part studio, no matter the shape; rectangle, multiple lines, polygon, none of my tools can select edges. Even if I right click and use the custom selection, it only registers the edges if I then drag a box around all the edges I want, which surely is not the intended way of doing things, right? (Because I cant drag and select entities when using a tool either way)
Is there some setting I have accidentally toggled that's causing this?
CADNurd
Member Posts: 155 ✭✭
I don't think Brave is officially recommended/supported - try the checker below and then maybe switch to Firefox.
Unemployed Onshaper- Operating on European time - More of me here ➤➤ https://linktr.ee/Liam.G0
Could you share the document, or at least a screenshot?
Your Operating System and Browser info would also be useful to know.
Unemployed Onshaper- Operating on European time - More of me here ➤➤ https://linktr.ee/Liam.GAs per usual, it has suddenly started working (on fresh documents). Sorry for the wasted time
Actually, on this one document it still seems to have the weird behaviour;Link: https://cad.onshape.com/documents/303129940e840eeaa875a0a8/w/62e58df0a0a345e9de1f3dfc/e/1e367dde3e0551a3db6878f2
Everything works now, unclear as to what was causing it
OS: Ubuntu 25.04
Browser: Brave
https://cad.onshape.com/check
