Challenging sketch constraint with variable text - not mission critical!
sasha_sklar061
sasha_sklar061 Member Posts: 34 ✭✭
I have a use case where I'm populating a text block from a configuration variable to emboss onto a face and depending on the length of the text it either breaks out either horizontally or vertically. Plenty of ways to work around it but I'm curious if there's a "pure" sketch constraint approach…
Screenshot 2026-03-25 at 10.31.41 AM.png Screenshot 2026-03-25 at 10.28.56 AM.png
I'm probably going with an expression approach that pads with whitespace if the character count is below a give length…
