Drilling hole on the opposide side
michal_bartak
Member Posts: 17 ✭
Recently I faced this problem several times asking myself is there any shortcut for that. Hence motivation to write this post.
I draw a sketch of the object to be extruded and the point positioning a future hole.
I extrude the object and then attempt to create a countersink hole directed from the top surface of the object.
At this stage, using the already created point gives me the option to drill the countersink hole from the bottom to the top (from the sketch surface) only.
Is there a simple/quick way how to drill the hole from top surface without creating another sketch with a plane set to the top of the object's surface?
Here is on shape document for example from screenshot above: https://cad.onshape.com/documents/1098f17aa2583b24d99e166d/w/1294ceada4789d58d410b8d6/e/69368c49a561fcc1df036277?renderMode=2&uiState=63d28a1bef705502fc6055bc
thank in advance
thank in advance
1
The only way I can think off is using a mate connector centered on the sketch point. However you may still have to re-orient it as well as add an offset larger than the thickness of the extrude so quite a few clicks still...
It would be nice if it was smart enough to look "the other way" when you flip the direction (and you don't have the "start from sketch plane" option selected)
1
1 -
I've run into this a lot lately.
I agree with Eric. If the direction good be flipped it would be a time saver.0 -
Thank you guys for confirmation0
Any update to this? I am running in a similar problem all the time and it feels like the hole tool is 99% there, just needs a few different settings available.
It appears so. The hole can be drilled both directions. Just use the opposite surface as the starting surface. You can re-use the same point for the hole center.
