Onshape is unnecessarily lagy, What can I do to fix this.
bailey_wilson117
bailey_wilson117 Member Posts: 2 ✭
Despite following all recommended troubleshooting steps provided for improving performance, the issue with Onshape remains unresolved. All suggested fixes have been implemented, I have also check my system throgh onshape at it is fine. Diagnostic tests indicate that the hardware and meet all required specifications, with no errors or performance limitations detected. Therefore, the ongoing lag appears to be unrelated to local system performance and may be due to external factors within the platform itself.
  • NeilCooke
    You're connected to the server in Sydney, yes? I see there is not much modelling activity on your account - what are you seeing that is laggy?
