Auto Layout leaves one part "out in space" and non-planar
eric_fisher438
eric_fisher438 Member Posts: 11 ✭
Hello everyone. I'm trying to layout parts of a speaker cabinet to cut from a plywood sheet on CNC. When using the Auto Layout FeatureScript all but one of the parts is laid out nicely on the sheets. For some reason the script leaves one of the parts "out in space", does not place it on a sheet, and has it angled on a different plane than the other parts. Here's a screen shot of the result of using Auto Layout- you can see the one gray part that didn't make it onto a sheet down in the lower left corner:
Here's another view of the same layout, showing that one part is not planar with the rest of the parts:
Any ideas why this is happening? I'm grateful for any help from the community, and thank you.
https://cad.onshape.com/documents/ae622757f483f2f31a0dcc01/w/3fb0240ad296a16db105d28f/e/b3af554ec9fb712448bed9c2?renderMode=0&uiState=69db9b98e1d1cebdb5e2103b
