Reverse Engineering Shape with Surface Modeling
rubenskaya_pooprubenskaya_poop Member Posts: 11 ✭
I have this shape that I want to reverse engineer , im not very great at surface modeling and its giving me headaches I tried doing a loft extrude and thinking I would cut the excess material on top with some kind of surfaces but I can find a way to do it properly. Please guide me for the best way to reverse engineer this shape.πŸ˜€
Here is the link : model
  • jelte_steur_infojelte_steur_info Member Posts: 673 PRO
    Answer βœ“
    perhaps a single extrude with some draft may work.
    It depends on how precise you need it to be. Best thing is to create a surface bigger than the loft and trim (split part) it in one go.
    the surface could be a constrained surface, or is it perhaps close enough if you revolve a surface?
