can i visualize a projekt with a gantt diagram?
derk_bossel
Member Posts: 2 ✭
Interesting question. I was asked that years ago, when still on my old CAD. The intention was to align the CAD project with shop flor management. I found a way to extract the assembly tree as an XML file, and that could then be turned into all sorts of diagrams. Depending on what you're up to: Would the BOM be a good starting point for this?
Do you mean a diagram of the connectivity of a document or between documents? I've done something similar recently for finding circular dependencies and duplicated versions. Something like this could be modified to work for part studios as well:
Is that done via some kind of JSON/XML export and
dotor did you use something else to generate the diagram?doc traversal via api and graphviz (dot) for render.
I assume the original post was about a Gantt chart for tracking tasks, subtasks and milestones in a project.
The quick answer is no, Onshape doesn't do that.
Onshape does have basic task tracking:
https://www.onshape.com/en/blog/tasks-key-benefits-use-cases
That said, @jnewth , I'd love to see a document reference visualizer like that.
