Is it possible to create a through all hole that is threaded on both ends?
André_Medrano
Member Posts: 2 ✭
I have tried this with different methods but every time i end up with just one thread on one end, i have not figured out how to keep thread on both ends
AFAIK not currently possible. Try making a through hole without any threads and use E.G. ThreadLab FS to make the threads with defined depths.
The only way I've been able to do it is to cheat with a break in the middle:
https://cad.onshape.com/documents/2b33766d409c36d72e421160/w/891aa16ef6f555a44b547dcc/e/9adfd5117ab6eb277864f06f?renderMode=0&tangentEdgeStyle=1&uiState=69f10408e81c07fede89a2a5
In theory all you need is a split face in the middle but the standard tools will all merge the faces of the holes if you try to make them the same size again…
