I can´t model the joint. Could anyone kown? Fillet doesn´t work. Thanks in advance
carlos_martín065carlos_martín065 Member Posts: 6
  • robert_scott_jr_robert_scott_jr_ Member Posts: 825 ✭✭✭
    Hello Carlos. Not sure how you modelled that ear. I think the fillet was the result of a sketch face that was extruded. What is needed is to have the ear and that tunnel joined as one part and then apply the fillet. This document has a couple of methods to attain that. - Scotty
  • S1monS1mon Member Posts: 4,269 PRO
    It also looks like you have several parts, not one. You want to use “add” with your subsequent extrudes so you get one part.
  • carlos_martín065carlos_martín065 Member Posts: 6
    Thank you so much, Robert and Simon!
    Your answers cleared up my doubts! I made a mistake in the first sketch, and thanks to you, I realized it.
    On the left, you can see my first (incorrect) sketch, and on the right, the second (correct) one.
    Thanks again!
