Best way to set up "configurations" with large numbers of feature differences
Hello!
I am trying to set up a 3D printed box that the base features are the same and "linked" but there quite a few features between 3 different versions that are dissimilar. Originally I made the first box and then duplicated and changed as needed. Later I found out one of the features common to all 3 were incorrect. I am now faced with changing the same mistakes across all 3.
I believe the best/correct way to do this would be to set up configurations however going through and clicking check boxes across ~75 features in the configuration panel feels inefficient and that makes me think there is probably a better way or method. Would it be better to have the base part in 1 part studio and derive that into 3 new part studios for each "version"?
Screenshot:
The part: https://cad.onshape.com/documents/7be754cbdf3fdfaea8bf6e25/w/1ddc1b92fd6342355c8e14ff/e/0f37a009e6f4f7e50f2447df
Please feel free to ask any questions or provide any feedback, thanks!
Nevermind I found the Onshape Configurations Learning Pathway.
For anyone with a similar question this is probably the resource you're looking for:
https://learn.onshape.com/learn/learning-path/onshape-configurations0
