Can you use "conditionals" with variables?
brian_brady
brian_brady Member, Developers Posts: 505 EDU
What I mean here is can you do things like; if x>10 then y=0.5*x else y=x. What about logical functions like AND and OR? If conditionals and logicals could be used, then I could easily "program" multiple variables to change off one or two primary parameters. For example, enter a woodruff key number (i.e. 204) into a variable and use conditional logic to set all of the dimensions. Diameter and thickness can be done without conditionals, but the offset cannot, it varies from size to size.
On the other hand, can FS be used to just import existing variables and set values to new variables that can be used in a part model without actually making any geometry?
  • brian_brady
    Great. Thanks for the answer. Can AND and OR be used, maybe as && and ||?
  • ilya_baran
    ilya_baran Onshape Employees, Developers, HDM Posts: 1,277 image
    Yes -- exactly && and ||.
  • jonathan_monette
    jonathan_monette Member Posts: 34 ✭✭
    Is there a list of these logical variable control that I could refer to? Or documentation's?
  • MBartlett21
    MBartlett21 Member, OS Professional, Developers Posts: 2,064 ✭✭✭✭✭
    @jonathan_monette
    These are just standard javascript constructs
  • ilya_baran
    These are not JavaScript but FeatureScript -- there's some syntax similarity, but it's unrelated otherwise.  Documentation "for mechanical engineers" is here: https://cad.onshape.com/help/Content/numeric-fields.htm?Highlight=expressions but is incomplete.  A more complete description is in the FeatureScript documentation: https://cad.onshape.com/FsDoc/syntax.html#expression-types
    Note that what you enter into the expression fields is not quite FeatureScript syntax.  The main differences are that shorthand units (eg., "in" rather than "inch") are allowed, the multiplication before a unit is optional in some cases (as in "3 inch" rather than "3 * inch"), #foo for accessing context variable foo, and a couple of other minor differences.
  • ronald_grosmann
    ronald_grosmann Member Posts: 2 ✭
    Great question, but no answer after 10 years?
  • NeilCooke
    I see lots of answers above. All of them correct.
  • EvanReese
    @ronald_grosmann I agree it seems like it's been resoundingly answered already in the thread. If you want to dig into this stuff more, I also have a Youtube video on the topic here.
