Revolve Axis Cannot Be Selected
dn368
dn368 Member Posts: 6 EDU
Hi All,
I am having trouble getting a line to work as a revolve axis. I have created an initial sketch with a circle and need to update it to an ellipse so I've create a new drawing on the same sketch and planned on simply changing the revolves I created with the circle. However, when I go to select the revolve axis on the new ellipse the line is not selectable. I've tried many things and ensured I'm selecting revolve axis but hovering over the line in the ellipse does not highlight (the old sketch is still available however so it seems that it must be something with my drawing). I've done this a number of times with other curves but always with circles, does it matter that the line is not from a circle?
Here is a link to view the document: https://cad.onshape.com/documents/4ab92b5a4f5493699e38ac47/w/913484fcfdad8629153186f1/e/506bcc15716faefcc8f2792d?renderMode=0&uiState=6a0319c5bbc25205eb30314a
(See "Bot Rings" document)
Thank you for your expertise!
  • eric_pesty
    Revolve is by definition circular, if you want to follow an elliptical shape, you need to use the sweep feature instead.
  • dn368
    Thank you @eric_pesty! I was able to get sweep to work but was hoping to replace the parts with the same process to avoid additional work.
    If I used the same name on a new part will be replaced in the assembly or will each part need to be inserted and mated again either from scratch or via 'replace <part name>' tool?
  • joshtargo
    as Eric said, but also these entities, as per the docs:
