How to hardcode files for opImportForeign?
joshtargojoshtargo Member Posts: 610 EDU
How can I hardcode the blob data so a user can select from a list of STEP files from a dropdown list?
I've tried many different things but nothing works. this is the starting point with a single imported file for a test.
FeatureScript 2960;
import(path : "onshape/std/importForeign.fs", version : "2960.0");
import(path : "onshape/std/feature.fs", version : "2960.0");
import(path : "onshape/std/common.fs", version : "2960.0");
Part1::import(path : "4e82d1e61d46ecc058c3ab67", version : "797f1d3b6c8dd334df5c46ba");
annotation { "Feature Type Name" : "Import", "Feature Type Description" : "" }
export const myFeature = defineFeature(function(context is Context, id is Id, definition is map)
precondition
opImportForeign(context, id + "importForeign1",
"blobData" : Part1::BLOB_DATA as CADImportData});
  • Caden_ArmstrongCaden_Armstrong Member Posts: 453 PRO
    Could you use a derive of the imported model?
  • joshtargojoshtargo Member Posts: 610 EDU
    It becomes significantly slower to use derive. But would the same syntax work for either? I just can't make it work.
    Bump
  • wille_jwille_j Member Posts: 106 ✭✭✭
    I had a quick poke around out of curiosity, here.
    In short, I can't get it to work either, only via the predicate import:
    annotation { "Name" : "CAD model" }
    definition.cadModel is CADImportData;
    This seems to do some additional processing of the blob that also write processedForeingDataInfo to the blob data. See the different debug printouts. I can't find a way to process this at the FeatureScript level, so my best guess it's some processing happening behind the scenes in the C-level at feature computation.
    I have a feeling this is the best one can do to select blob 3D geometry in FeatureScript as it stands. But you're definitely onto something, there is a significant difference in regen time between native derive and the CAD blob import.
    But, the native derive do a lot extra processing, using the more plainopMergeContexts does show some nice improvements. All variants are in the same document to have a look at.
    Hope any of this helps 😃
  • EvanReeseEvanReese Member, Mentor Posts: 3,002 PRO
    @wille_j I played with it too and ran into the same exact thing and same conclusion. I sort of thought it might be simple since the code for an import feature is so dang simple.
    FeatureScript 1746;
    import(path : "onshape/std/geometry.fs", version : "1746.0");
    icon::import(path : "dbbb95dc4b30445fafe0ff6d", version : "17a1cb30b1bd13b6dd31b29b");
    annotation { "Feature Type Name" : "Import 3D File",
    "Icon" : icon::BLOB_DATA}
    export const importFeature = defineFeature(function(context is Context, id is Id, definition is map)
    precondition
    annotation { "Name" : "3D File" }
    definition.file is CADImportData;
    opImportForeign(context, id + "importForeign1", {
    "blobData" : definition.file
    Thank you both. It's a bummer because I could have a huge prepoulated organized list of items to import, basically a mini app. But I can build it all into a single parts doc of STEP files and select via doc browsing.
    @wille_j the other main difference is that derive can bring in native Onshape parts, and import can only do downloadable cad files. Can any of the other methods bring in Onshape parts from studios?
    Not sure I follow your question, and maybe you're already familiar with the instantiator stuff, but on certain features I've set them up to access pretty complicated parts libraries via a lookup table path to dig into it. The terminal node of each path ends in the build function instantiator needs. That way you can set it up to narrow down to the final selection like Metric → Inserts → Heat Set → M5, and get back the model you want. Here's a 1-layer example, but your table can go deeep. Might not be quite as zippy as a straight import, but for many things is plenty good. This does, of course, bring us back to the other thread about how in many cases bringing the hardware directly into the Part Studio isn't a recommended general practice though for a number of reasons:
    Performance issues - merging contexts (aka Derive) can bog it down.
    Part search can become a nightmare - if you search a part from the document dashboard everywhere it's derived will come up because Onshape sees them as unique parts now. How do you know which one is "the real one"?
    BoM issues - You want it to show 1 screw 10x not 10 screws 1x.
    https://cad.onshape.com/documents/9840ec2b6d75757f8b4ad7c7/w/6da09b0068c9fad6999e2811/e/9417ae113a3138e3d30bfe5e
    @EvanReese , can you Public that doc?
    my bad. I'm the worst about that. done.
    np, i tried with a typical part from another doc, and then tried the same test inside the doc with the part (but pulling from the Version). times are similar between the two. If I derive from the active workspace, it's a little slower, the other two don't change.
    Is your Instantiator neither a derive, nor an import? Is there a normally available feature or workflow that uses Instantiate? It's faster than derive for pulling in part studios (rather than STEPS via my Import). And I love that yours has a dropdown list, which is what i've been wanting to do with ImportFS
    Instantiator is at the core of Derive, but I don't know what else Derive is doing to drive the time up. I'm interested to know if the difference you see is additive or multiplicative. In other words, is the difference always 28% or 34ms? I suspect the latter is closer to the truth.
    Yeah, instantiator is the FeatureScript-name for Derive. Same thing under the hood. Time-wise I believe it's mostly just doing so many additional checks and balances as a native user-facing tool, that a custom instantiator-tool never bother with.
    I don't quite understand this question, but I'll try to expand. Instantiate and mergeContexts can bring in Onshape-designed parts too, opImportForeign is the only one that can grab a blob. Essentially, instantiate and mergeContexts can only point to an existing part studio to get stuff from. opImportForeign can only point to the plain (unprocessed) .step/brep file.
    The way I see it there's two routes to get your import mini-app:
    1. Use opImportForeign, dump all step files in some sorted documents. Make sure those documents are easy to find by user browsing the GUI selector in the FeatureScript. No scripting overhead to add more files over time, a bit clunky in GUI to find the right thing.
    2. Us instantiate or mergeContexts, build a lookup table for your parts and do all the part derives from those part studios that are automatically created when imported in the first place. More scripting overhead to add more files (one have to update lookup table and add imports), but can be a very polished GUI to find the right thing fast.
