Custom Feature: Custom Font Text
This feature is a fork of the Text feature and allows you to upload custom fonts to use with it.
How To
- Visit to convert a TTF font to a JSON file.
- Import the JSON file into your document.
- Add a Custom Font Text feature and select the JSON file
- Configure the rest of the Custom Font Text feature like you would the Text feature.
Todo
- Improve kerning support. Only basic x axis kerning is supported.
- Add ligature support.
- Improve language support. Low priority unless there is a demand for it.
If your font doesn't work or doesn't look right
Post the TTF, optionally include a document and I'll take a look. I'll prioritize fixes for fonts that people want to use.
Looking for feedback on these
Construction bounding box
You'll probably notice that for a lot of fonts the characters are much smaller than the construction rectangle. I was thinking of an option called "fit to height" to resize the text so that the largest character was the specified Height option. This would cause the text size to be unstable as the height would change as you add and remove characters.
Characters outside the construction rectangle
The bottom edge of the rectangle is the baseline. Some characters such as "g" will go below it. Would you prefer characters stay within the construction rectangle? A separate horizontal construction line could be added for the baseline.
Wingdings support in Onshape is my current favorite feature of 2026 and it's not close.
4 -
@bladec you may want to add your custom font support to the fontpicker predicate directly. This way anyone who builds a text-based feature can leverage your custom font work:
https://forum.onshape.com/discussion/23475/new-featurescript-predicate-fontpicker1 -
This looks very interesting but I noticed all the the examples in the linked doc appear broken…
@bladec when I wrote the original Text (what you're forking from) I created the Examples folder as a set of unit tests. If they all "look good" and/or match the "reference image" after I've made code changes, then I have (some) confidence that I haven't made any regressions. Perhaps worthwhile going through and figuring out what broke? Though I suspect it's all the same error and you'll be able to fix it quickly! But also: add a few examples that exercise your new functionality and use this as your unit testing as you expand on this feature.
1 -
They just needed a font selected. Fixed them on main. https://cad.onshape.com/documents/0268281ab84da24693d00fc3/v/13d06c05d860ecc243ce0d53/e/25bee37a96bbb121f9037a74
Do you mean have a predicate that lets you swap between built-in and custom fonts. That variable would then be passed to sketchText() so that the person adding this to their featurescript doesn't need to do anything special to get both built-in fonts and custom fonts?
1 -
@bladec Thank you for sharing!
I could really use a font which is a stick figure, meaning single lines. Is that possible to achieve?
Thanks,
@ben_partouch ive been working on something similar. What do you need? What do you mean specifically when you want a "single lines"? Does that mean each character is a single line, a collection of straight lines, or only simple lines and arcs or constant cross section (like what you get with a single diameter cutter when following the path) or something else? Ive been trying to bake it in to an annotation tool:
My goal when creating such a font was to make it "machinable" (either embossed or debossed) and so long as you use the font you know you won't get weird collisions or problems. The font is called "Machinable". But I ended up turning it in to other things over time.
Assuming you mean open contours, that's not supported by TTF. However this custom feature technically doesn't care about contours being closed. I could add support for converting SVG fonts to JSON which would allow for this if that is what you are looking for.
I added support for converting SVGs to the web page. I tested it with some of these single stroke fonts.
I couldn't find a good way to make my own. Fontforge doesn't support them. Inkscape's old typography extension kind of supports them but is quite broken. Inkscape's new svg font editor doesn't support them. When making my own for testing I ended up closing each contour and manually editing the SVG by hand to open them.
Query variables+ makes it pretty easy to work with the edges to do stuff like this. I'm sure if I spent some more time on it I could smooth out those corners. https://cad.onshape.com/documents/54c2b2dbcad2d9a233387ec4/w/6e033d1b75f8eff1c3e5dc94/e/b6e63f55cf8d7f7b6b134a1b
Oh wow! that was a nice read!
And to do it the proper Gorton way: if you got nice curves - i like the pipe edges FS by Evan. it makes pipes with rounded ends. does not have a remove option - yet.0 -
@jnewth it is to be machined. We use a marker as one of our tools to label the nested parts we cut on a CNC.
The fonts currently available are double lined and made out of complex curves.
So I need a font that is both single line and made out of straight lines and arcs, nothing else. This saves time both computing the parts and marking them.🙏
I think the real issue is that you can't split a face without a closed shape..
That font should be fixed now if you update to the latest version.
I'm at a laser sheet metal house, really need "stick" lettering to save time when etching part numbers, instructions, etc on parts. The laser etches much slower than it cuts, so it's a real issue for us.
Tried to get a ttf font, Stick, to work but no luck.
If this font or one like it could be made to work with this feature it would be a true game changer for me,
Thanks in advance!
Fred Burtt
That document is view only so I can't review the parameters. I tried the first result for "Stick Light TTF" and that one worked for me. https://cad.onshape.com/documents/58fa611eac120d71f24c98c7/w/d99cbd1f667c42db1622de71/e/3c2311e5f286db0fafebee7d
Wasn't it all about a single-line-text? Else, it would not make laser engravin any faster, if the lasr had to run around the outer and inner line anyway.
That still doubles the time.
TTF doesn't support open paths. The feature does support open path svgs. For example you could use this font if you need a real single stroke font.
Thanks, bladec, for digging into this. Here's the doc made public:
I've tried the Stick font and one named Forge, with no success, so good chance I'm doing something wrong.
Martin's right about the double-line issue, though. That font looks like what I'm after, but will still take double the time to etch.
I wonder if it was possible to write a FS that had the curves for all the one-stroke characters hardcoded in itself, possibly in a 'courier' style with constant width for all characters, and have it place them all along a base curve or on an MC specified, in a height set in the dialog. Kerning wouldn't be needed. That feature would not need to be universal as in it being able to produce a choice of fonts. One Font would be enough.
Could the import spline points workflow be used?
Yeah @martin_kopplow I have a stick font as you describe: true single stroke elements. The problem is exporting this data. A couple ways:
1. Use a custom feature to create a sketch. Export that as DXF. — Doesnt work. Not an option on FS-generated sketches.Here's the context menu on the manually created sketch:
2. Import a custom feature-generated sketch in to drawing, then export that as DXF. — Doesnt work, can't import FS-generated sketches.(FS-generated sketch isn't even an option for insertion).
3. Use a custom feature to create a sketch. Then manually create another sketch on top of that one, and "use/project" all the sketch elements in to this manual sketch. Export that as DXF — Works but a rather unpleasant process.
4. Use a custom feature to create a sketch. Have this same tool also output (as text) the gcode required to describe those toolpaths. —- Could work, but moving gcode in to FS, while possible, is a little nasty.
If anyone has a workaround or solution to the above I'd be interested in hearing about it. The stick font I can provide with little trouble at all, but the export remains an unpleasant business. There are many ways (write my own exporter / file dumping API script / gcode generation) but i cant think of one that people would you know, actually use.0 -
Looks like you used the wrong facetype.js to convert the ttf. You have to use the one linked in the post. Due to limitations in featurescript, facetype.js had to be forked and modified. The original facetype.js won't produce a compatible json file.
That did the trick 👍️
Thanks so much, bladec.
Now to load some fonts!
Is it possible to then alter the sketch of the character? I'd like to change the shape of the created letter. I'm a little unclear as to how to separate the sketch that contains the drawing of the text out onto a completely separate (and unconstrained) sketch. The 'use' tool will let me project it into another, but it's constrained to the original.
Hi everyone.
Has anyone found a way to have the text easily centered in a face / path?
That's not manually moving the path and character offsets I mean.
I'm trying to recreate the numbering below (from a model I got from Solidworks with text in Century Gothic.
Whenever the text changes, I have to adjust the path left/right0
