Is there a Featurescript that has additional fonts?
Thank you bladec. I forgot I was logged on to the Forum so I wasn't aware I received an answer.
I have located a TTF I would like to use. Went to Facetype.js, chose the TTF, selected "Reverse font direction" (Because I wanted to try the 'R'), selected "Restrict character set" and input the 'R', then "Convert". It downloaded a file with the TTF chosen with the extension .json, but from there I am a bit confused as to what comes next.
- In the bottom left of the document select "Import" and import that json file.
- Create a sketch and draw a line to use as a path later
- Create a Custom Font Text feature
- Click the "Select JSON file…" option and select the imported font
- Click "Path" and select the sketch line
- Add some text
For examples of the various options see the feature's example folder. https://cad.onshape.com/documents/0268281ab84da24693d00fc3/w/92e9d02adb082f5f6a73820f/e/8c1cdf522e3d35677a49a6de
