My boolean operation failed to return a valid part
saar_mano
Member Posts: 2 ✭
I can't seem to understand why….
https://cad.onshape.com/documents/fea3481be553b841a27e3bad/w/e3655c909a7b53dc0c90512b/e/fc63d3c377c24dab29a48346
It looks like you might be making non-manifold geometry with the resulting solid. It works if you turn that sweep into a solid, rather than sweeping the surface and thickening.
