Calculating with variables only works with * and /
Calculating with variables only works with * and /. When I try to use + or -, the field turns red. What am I doing wrong?
Example: #high+3
Simon is right. Here's a video I made a while back that will hopefully help build an intuition for it
1 -
Kevin also wrote a good explanation for units way back when:
If it helps: internally, everything is in base units (meter, radian, etc.), so, if you write
2 in, that evaluates to2 * 2.54 * centimeter=2 * 2.54 * 0.01 * meter=2 * 2.54 * { "value" : 1, "unit" : { "meter" : 1 } }. Math operations check at runtime whether they're valid and error out when an unsupported operation occurs, like adding a unitless5to a length. Multiplication, of course, is valid, except when you end up with stuff like an area in a length field.0
