Having issues with making jigs using boolean and hollow parts
Hi,
I’m currently working on creating various jigs for parts that we manufacture. This works well for solid parts using Boolean operations, but I would like to achieve the same result with hollow parts, as shown in the picture.
Is there a way to create only the imprint of the outer or inner surface of a hollow part, rather than simply subtracting the entire part from another object? Ideally, I would like to use the surface geometry to create a matching fixture or jig.
Also, the offset function doesn't seem to work for a lot of parts with more advanced geometry.
Thanks in advance.
  • EvanReese
    EvanReese Member, Mentor Posts: 3,091 PRO
    It might be simplest to fill in the reference part then make the fixture.
  • martin_kopplow
    martin_kopplow Member Posts: 1,641 PRO
    You could always delete the unnecessary faces (that'd be the inside, then, I suppose) and model from there, connecting the outer surfaces to your jig basic shape. It is not like you're limited to solids.
