Merge Two Projects to One
Hello,
What's the easiest way to copy a part from a different project to another?
  • robert_scott_jr_
    robert_scott_jr_ Member Posts: 930 ✭✭✭
    Hello Sergio. If it's just a part you want to 'import' into another document The Derived tool can be used. You can copy an entire Part Studio into another document by right clicking on the tab of a part studio and select Copy to clipboard. Then go to the document you want to have the part studio in and click the plus sign at the left end of the tab bar and select Paste tab. - Scotty
  • sergio_castro538
    sergio_castro538 Member Posts: 6 ✭
    Hey Scotty,
    How do I get the part from one tab of the clipboard into another. I'm still unable to paste one part to different tab on the clipboard. (Reference Images).
    I want to combine these two parts in one tab.
    Regards,
    Sergio
  • nick_papageorge_dayjob
    nick_papageorge_dayjob Member, csevp Posts: 1,261 PRO
    Are those two separate parts meant to attach together with glue/screws/friction/etc?
    If so, you are looking for an onshape assembly.
  • robert_scott_jr_
    Did you try Derive? - Scotty
  • sergio_castro538
    Scotty,
    Where is Derive located?
  • sergio_castro538
    Scotty- I found it. Thank you
