How to add a border to text
ElClipo
Member Posts: 3 ✭
I made the following keychain as a way to learn how to work with text, etc. Very simple design but it is very time consuming to do the bottom layer to be shaped around the letters. Is there an easier way, other than drawing and manipulating it by hand? If it exists, I would like to know a way to be able to change the text and have the edge adjust accordingly. I hope that makes sense.
Hi ElClipo,
For this case, I would try to make duplicate parts of the text that are directly underneath and use 'Move Face' with offset. I started with the text, extruded it, them mirrored it. Then with the move face command, I used the 'Arrow' for the selection commands to easily select the outer faces and offset them a desired amount.
Then sketch on the bottom to clean it up some and do an extrude with a boolean to combine them.
Then boolean everything together
Jake RamsleyDirector of Quality Engineering & Release Manager onshape.com7
Hi ElClipo,
Jake RamsleyDirector of Quality Engineering & Release Manager onshape.com7 -
Thank you for the suggestion. I had tried that but I guess I used the wrong settings. I got it to work pretty easily this time with your suggestions. In the end I didn't have to sketch anything after the Move Face. I extruded the center of the letters as Blind in the opposite direction to match the Mirror. Then I selected all entities and used the Boolean to Unite them. Lastly I sketched and extruded the circle for the key ring.
All in all much quicker than drawing it by hand.
This seems so confusing and I cant get the hang of it in any manner if anyone sees this please check my profile and see my only discussion0
ian_mott426 said:This seems so confusing and I cant get the hang of it in any manner if anyone sees this please check my profile and see my only discussionIan, I would suggest you take a look at the learning center. Go to the free self-paced courses and begin with the basic courses that have a green labels (more than one). This is probably the easiest way to self teach. My advice is to go through them, picking up what you can and revisit them later, again and again. It seems like you pick up something new every time you go back. Keep your starting projects simple and build from there once you gain more knowledge.Good luck , and stay with it. (my apologies if this got off topic)1
Hello, I did it in other way
Here’s how I did it in Onshape:
- Create a new plane on top of the extruded letters.
- Mirror the part across Plane 1.
- Use Move face and select the face of Mirror 1. Set Offset → Blind, enter a distance of 0.2 cm, and enable Reapply fillet. ✅
- Use Shell to hollow out the part, with a shell thickness of 0.15 cm. ✅
I can print this in two colors even though my printer doesn’t support multicolor printing, by adding a pause in the slicer and manually changing the filament. 🙂
