Can't extrude, and I'm certain I'm way off... HELP :-)
Hello all, and thank you for taking the time to look! I cannot get this car profile to extrude, and I've tried everything I know. I'm certain someone here with much more experience will either have an answer, or know that its not possible…could you please let me know?
Here's the link to the project:
https://cad.onshape.com/documents/a3027175ca2975b50e7605be/w/5d7cefe54da97fb6e0d96271/e/c89595518c3e0253abdb8cb1?renderMode=0&uiState=6aba56154584f1e9f4be11ca
  • Nameorus
    Nameorus Member Posts: 33 EDU
    edited September 29
    it is VERY undefined and isn't really in a sketch format, it seems to be more like a perspective drawing of some sort. if you are trying to model the car, I would suggest you use that image as a reference and start a side view sketch from scratch.
  • Mikayla_Lambert
    Mikayla_Lambert Member Posts: 5 PRO
    the two curves making up this feature overlap or merge into the same line. if you change the angle of one of them or trim off the end of both then you can extrude
    https://cad.onshape.com/documents/d00a17535b59b005832600a8/w/ee4b8bde81684fd8d9a44af0/e/a903d3184178f03c0cd2c192
  • Nameorus
    you still there bro?
