How to speed up Onshape?
Nameorus
Nameorus Member Posts: 65 EDU
edited September 30 in Community Support
UPDATE: This issue is resolved, thank you for helping.
Every time I make a SINGLE edit or even open up a sketch, there is a ~20-30 second wait time while that wheel spins. The regeneration time is even listed as 23.46 seconds despite my computer being able to render 30.7 million triangles per second and my effort to leave plenty of free ram space for Onshape to use.
  • john_rousseau
    john_rousseau Member, Onshape Employees, Developers Posts: 428 image
    Please open a support ticket. That seems quite wrong, but having support look at the document is going to be critical.
  • Kevin_Cowles
    Kevin_Cowles Member, Onshape Employees Posts: 90 image
    Part studio regen time is 100% independent of graphics card and RAM. It's quite literally a measure of how long the features in your Feature Tree take to rebuild (which is a shared process in any parametric CAD system).
    If you tab out "Feature" you'll see the specific times for each feature in the Part Studio, but you can already see from the summary that Loft 3 is taking 23.6 seconds. So I would investigate trying to improve that feature's performance (breaking it up into multiple lofts, or simpler curve inputs for instance). OR if you're working upstream of the Loft 3 feature, then suppress or roll back above Loft 3 to make the tweaks. Then if will regen in under 2 seconds, and you can iterate quickly before rebuilding that very expensive/slow Loft3 feature.
    Check out the Part Studios portion of the Maximizing Document Performance course: https://learn.onshape.com/learn/course/maximizing-document-performance
  • john_rousseau
  • Kevin_Cowles
  • Kevin_Cowles
    (and also log a support ticket, good point John!)
  • Nameorus
    the thing is, loft 3 has only 2 profiles and no guide curves and STILL has 8844 triangles! The end conditions are "match tangent" on both profiles and there are a lot of filets though.
  • RhettRobinson
    RhettRobinson Member Posts: 250 ✭✭✭✭
    Anecdotal for sure, but anything under a few hundred million triangles per second has been slow when I have modeled. This is what mine is running at. Your problem definitely sounds like it needs a support ticket and checking your internet speed.
  • Kevin_Cowles
    Hmmm could be the fillets + end conditions that are causing it to balloon. Kinda impossible to help without seeing the doc so def would log a support ticket and toggle share w/ support! They'll have better expertise than me anyways
  • shawn_crocker
    shawn_crocker Member, OS Professional Posts: 1,071 PRO
    Just curious what time zone your in? I'm in est in Ottawa Canada. Almost every day, after 1:00pm we experience alot of slowness just like that. Slowness that just can't be directly connected to a big part studio. While support isn't explicitly calling bull on me, there tracing reports claim not to really be picking up the pattern every single person at my company feels with glaring discomfort most days. I am currently, undergoing a process of feeding them times a slow event occurs. This suspiciously feels like I'm just being hung out to dry in hopes I will grow tired of reporting on an issue Onshape either isn't capable of detecting, or isn't capable of solving and isn't allowed to admit it.
