how can i fill in this extrude in between the extruded lines
victoria_sabella
Member Posts: 1 EDU
It would be easier to tell if you shared the document, but maybe you're extruding a surface and you need to extrude a solid? Or if those are surfaces, you can use two more surfaces and an enclose to make a solid.
extrude the area between the lines as a solid
