how can i fill in this extrude in between the extruded lines
  • Matt_Shields
    Matt_Shields Member, Onshape Employees Posts: 1,002 PRO
    It would be easier to tell if you shared the document, but maybe you're extruding a surface and you need to extrude a solid? Or if those are surfaces, you can use two more surfaces and an enclose to make a solid.
  • Nameorus
    Nameorus Member Posts: 65 EDU
    extrude the area between the lines as a solid
