Is there a way, how I can delete coplanar edge from a flat surface?
libor_matula
Member Posts: 2 ✭
I would like to have coplanar surfaces flat without edges in between them.
Hello. It helps to post a link to your document if you are able. - Scotty
delete face or replace face should both work. i wonder if it really is coplanar though…
2 -
turn on the "tangent edges hidden" setting to check if they REALLY are coplanar.
1
