Is there a way, how I can delete coplanar edge from a flat surface?
libor_matula
libor_matula Member Posts: 2 ✭
I would like to have coplanar surfaces flat without edges in between them.
  • robert_scott_jr_
    robert_scott_jr_ Member Posts: 948 ✭✭✭
    Hello. It helps to post a link to your document if you are able. - Scotty
  • jelte_steur_info
    delete face or replace face should both work. i wonder if it really is coplanar though…
  • Nameorus
    Nameorus Member Posts: 65 EDU
    turn on the "tangent edges hidden" setting to check if they REALLY are coplanar.
