how do I change my mesh to solid
john_casey334
john_casey334 Member Posts: 2 ✭
  • uday_khatry
    uday_khatry Member Posts: 2 ✭
    Onshape will only turn a mesh into a usable solid if it's closed (watertight) and reasonably small. Things to try:
    1. Check the mesh first. PrusaSlicer, Bambu Studio or Meshmixer will report holes and non-manifold edges and can repair them. Export the repaired STL.
    2. Reduce the triangle count if it's a scan or a sculpt (Meshmixer → Reduce, or Blender → Decimate). Tens of thousands of triangles is fine; millions isn't.
    3. Re-import into Onshape. If it still comes in as a mesh, convert it to STEP elsewhere (FreeCAD is free: Part → Create shape from mesh → Convert to solid → Refined shape) and import the STEP.
    Expect a faceted solid: flat faces are editable, curved areas stay as many small faces.
  • Derek_Van_Allen_BD
    Derek_Van_Allen_BD Member Posts: 1,166 PRO
    You can try out https://untessellator.com/ as well. I made it specifically to combat the faceted conversion problem that most mesh converters suffer from.
