how do I change my mesh to solid
john_casey334
Member Posts: 2 ✭
Onshape will only turn a mesh into a usable solid if it's closed (watertight) and reasonably small. Things to try:
- Check the mesh first. PrusaSlicer, Bambu Studio or Meshmixer will report holes and non-manifold edges and can repair them. Export the repaired STL.
- Reduce the triangle count if it's a scan or a sculpt (Meshmixer → Reduce, or Blender → Decimate). Tens of thousands of triangles is fine; millions isn't.
- Re-import into Onshape. If it still comes in as a mesh, convert it to STEP elsewhere (FreeCAD is free: Part → Create shape from mesh → Convert to solid → Refined shape) and import the STEP.
Expect a faceted solid: flat faces are editable, curved areas stay as many small faces.
You can try out as well. I made it specifically to combat the faceted conversion problem that most mesh converters suffer from.
1
