Inverting ¨inside outing¨
tobi_botero_moriarty
Member Posts: 2 ✭
if i have a button that i made the one side that extrudes outward is there a way to make the opposite side that extrudes inwards? i need a quick easy way so that the extrude i made fits perfectly into a hole that is an ¨inverted¨ version of it. is that possible?
Hello. Have the part that you wish to have the button cavity in, abut the face of the body the button protrudes from and use Boolean/Subtract to create the cavity. If you are 3D printing, you may want to use Move Face to create a wee bit of clearance so the button fits snuggly in the cavity without getting stuck or depressed upon insertion. - Scotty
