Inverting ¨inside outing¨
if i have a button that i made the one side that extrudes outward is there a way to make the opposite side that extrudes inwards? i need a quick easy way so that the extrude i made fits perfectly into a hole that is an ¨inverted¨ version of it. is that possible?
  • robert_scott_jr_
    robert_scott_jr_ Member Posts: 948 ✭✭✭
    Hello. Have the part that you wish to have the button cavity in, abut the face of the body the button protrudes from and use Boolean/Subtract to create the cavity. If you are 3D printing, you may want to use Move Face to create a wee bit of clearance so the button fits snuggly in the cavity without getting stuck or depressed upon insertion. - Scotty
