I'm trying to make barbed wire for a project, I can't figure out how to do this
Alpha_Fok
Alpha_Fok Member Posts: 4 ✭
Can someone help?
  • wayne_sauder
    wayne_sauder Member, csevp Posts: 701 PRO
    Suggestion: create a path, use the MCP, and give the rest of the work to an LLM.
  • EvanReese
    I'd like to question the purpose a bit. Why do you need this modeled in 3D? It's challenging to create, probably slow to compute, and will also be slow to render all of that detail in assemblies etc. If you just need something to look like barbed wire, you could get an LLM to produce a png of barbed wire with no background, and use with a decal on a surface that's been made transparent. The visual would still be pretty good, and the regen and rendering time would be nearly zero.
  • Alpha_Fok
    I need to print this because my teacher needs a physical version of the project and not digital
  • Matt_Shields
    some sweeps
