Improvements to Onshape - November 20th, 2026
This release is about building smarter designs with less manual effort. Configure folder suppression lets you control a whole group of features with a single configuration input. The new Context Manager tab puts every in-context reference for a Part Studio in one place. You'll also find faster drawing cleanup, consistent file naming for batch exports, thread milling in CAM Studio, and more on Android and iOS.
PART STUDIOS
CONTEXT MANAGER TAB
Part Studios get a new Context manager tab in the right side panel that lists every context for the Part Studio in one place. See each context's assembly, named position, and affected parts at a glance. You can click on the reference assembly to switch to it, or right click on it to change the configuration or show and hide context instances. Out-of-date contexts are flagged so you know when to update, which is facilitated by an Update all out of context references button.
CONFIGURE FOLDER SUPPRESSION
Feature list folders can now be configured and suppressed as a unit. Configure suppression on a folder and it shows up as a single column in the configuration table, instead of one column per feature inside it. Suppressing a folder suppresses the folder itself rather than each child feature, so configured Part Studios with optional groups of features are much easier to build and maintain.
HIGHLIGHT SKETCH ENTITIES ASSOCIATED WITH DIMENSION
When you hover over a sketch dimension, the entities it's attached to now highlight. This makes it easier to see and understand the design intent behind each dimension.
ASSEMBLIES
HIGHLIGHT PARTS MISSING MASS FOR ASSEMBLY CENTER OF MASS
When you turn on center of mass in an assembly and one or more parts are missing mass properties, Onshape now selects those parts in the Instance list. Instead of a generic error, you can see exactly which parts need a material or mass override.
SORT BOM BY MATERIAL OR APPEARANCE
The Bill of Materials can now be sorted by Material or Appearance. Group parts that share a material for purchasing and cut planning, or that share a finish for painting and coating, right from the BOM.
DRAWINGS
MOVE MULTIPLE DIMENSIONS AND ANNOTATIONS TOGETHER
You can now move multiple dimensions and annotations at the same time in Drawings. Window select or multi-select the annotations you want, including weld symbols and callouts, then drag one of the selected dimensions to move them all together. This makes it much faster to clean up a crowded view or make room for other annotations.
IMPORT / EXPORT
EXPORT RULES FOR PART STUDIO BATCH EXPORT
Export Rules are now applied when you batch export parts from a Part Studio as individual files. Each part in the .zip is named using your company's export rules, so files come out consistently named with part numbers, revisions, or other properties, with no manual renaming.
RENDER STUDIO
IMPROVED SELECTION HIGHLIGHTING FOR TEXTURES AND APPEARANCES
In Render Studio, selected faces and parts now switch from a solid fill highlight to an outline while the Appearance property panel or the Projector dialog is open. You can see exactly how a texture or appearance looks on the selected faces as you adjust it, without deselecting to check and reselecting to keep editing.
CAM STUDIO
THREAD MILLING
CAM Studio now includes thread milling. Cut internal or external threads by circular interpolation using a single-point or full-length thread mill. You'll find it under Holes > Thread milling, with options for pitch, direction, passes, and lead-in and lead-out.
ROLLBACK BAR
CAM Studio now has a rollback bar in the job list, just like the feature list in Part Studios. Roll back to any point in a job to insert new toolpaths exactly where they belong in the machining sequence, instead of always adding them at the end.
NEW MACHINES AND POST-PROCESSORS
The following machines and posts have been added:
- Makera Carvera desktop CNC machines: Carvera Air, Carvera (C1), and Z1.
- A post-processor for ProtoTRAK SMX controls, initially with the TRAK TMC5 ProtoTRAK-GCD machine.
- A new generic Mitsubishi post-processor targeting the Mitsubishi M850 control, delivered as a 3-axis machine initially.
MOBILE
iOS: REDESIGNED NUMPAD
The numpad used when editing sketch dimensions on iOS has been redesigned to match current Onshape UI standards. It keeps the custom options you rely on, like tolerances and driving or driven dimensions, in a cleaner layout that's consistent with the rest of the app.
iOS: ATTACH COMMENTS TO SKETCH DIMENSIONS
On iOS, you can now attach comments directly to sketch dimensions, just as you can on the web. Flag a critical dimension or explain why it's set the way it is, and your team sees the comment tied to that exact dimension.
ANDROID: PARTS LIST PROPERTIES, DRAWING COMMENT TAGS, INFO AND SHARE
Onshape for Android picks up three updates that bring it closer to the web. The Part Studio parts list can now show part number, revision, and state when Display parts list properties is turned on in your account preferences. Comments tagged to drawing views and annotations on the web now display as tagged on Android. Info and Share have also moved out of the right side panel, to the top right on tablets and to the bottom bar on phones.
LEARNING CENTER
NEW ARTICLES
We’ve published several new Learning Center articles. They cover data management, release workflows, and building better assemblies:
- Understanding Release Management in Onshape
- Best Practices for Managing Data in an Onshape Document
- Onshape Categories
- Defining High Performing Assemblies
- Master Model Workflows
- Tips and Tricks for Working with Exploded Views
Please take a moment to try out these new features and improvements, and leave your comments below. For a detailed list of all the changes in this update, please see the changelog.
Remember: The updates listed here are now live for all users when creating new documents. Over the next few days, these features will also be available in documents created before this update. Mobile improvements roll out in the days after the release and are updated via the Apple App Store or Google Play Store.
"MOVE MULTIPLE DIMENSIONS AND ANNOTATIONS TOGETHER". I been waiting since 2020 for this.
2 -
"Export Rules are now applied when you batch export parts from a Part Studio as individual files. "
Ramon Yip | glassboard.com
4 -
Nice improvements! All look good - but especially love folder suppression, editing drawing annotations en-masse and export naming rules. Thank you!
3 -
Nice update, these are all very welcome improvements!
1 -
Nice updates!
We got GTA VI before "MOVE MULTIPLE DIMENSIONS AND ANNOTATIONS TOGETHER".
2 -
Good to see some of these "overdue" things finally added:
- Suppress folders in PS
- Export rules applied on multiple parts at once
The context manager looks like it will be quite useful too… The checkbox on isolate/transparent is also a nice improvement as using the ends of the slider was a bit goofy.
Always good to see a long list of "fixed" items in the changelog too, that often gets overlooked because it's not as "shiny" as new features but it's really important!1 -
Awesome quality of life improvements in this release. I'm particularly excited (oddly enough) about HIGHLIGHT SKETCH ENTITIES ASSOCIATED WITH DIMENSION.
2 -
Folder suppression is huge for my work! Thank you!
Nice to see more improvements to sketching!
