Combine hollow cylinder with sphere
CodyH
CodyH Member Posts: 22
edited January 2016 in Community Support
I have a hollow hemisphere I'm trying to add circular base to. I suppose this is essentially combining a cylinder to a sphere. I'm not sure if I'm supposed to combine the two separate pieces or cut a hole in the hemisphere and extrude the base from that. For now I have the two pieces sketched in Onshape but I have no idea how to put them together. Once combined the entire inside is open, including the base. The dimensions are as follows:
150 mm diameter hemisphere
70 mm diameter circular base (edited to fix the 66 mm in the image)
13 mm height for base; edge to contact on hemisphere
3 mm wall for everything
I have included a pencil sketch for illustration. I hope it is able to define everything I'm trying to explain. It seems this isn't very difficult, but I'm VERY new to Onshape and I can't find any tutorials on how to do this. Any help is much appreciated or if someone actually wants to provide a .stl I could work from then even better! Of course, I still need to learn. Thanks!
  • NeilCooke
    NeilCooke Moderator, Onshape Employees Posts: 6,099 image
  • jakeramsley
    jakeramsley Member, Moderator, Onshape Employees, Developers, csevp Posts: 669 image
    If I am reading it wrong and you want to create a single part that has a base and is hollow, then I would make a similar first sketch but instead of thickness make the entire thing solid.
    1. Make a similar sketch but rather than offsets, just connect everything so that you have a region going to the origin.  Likewise, the bottom line should be non-construction.  We've created two regions, but they are connected so they will both be used in the revolve.
    2. After revolving everything, start a shell and set the thickness to be 3mm.  Select the top face and the bottom faces.  What shell does is removes the selected face of the part and then offsets the remaining faces the set distance.  This will create a hole in the top and bottom of your part and everything is 3mm thick.
    If it is something completely different, I'll need some clarification.
    Jake Ramsley
  • NeilCooke
  • jakeramsley
    Do you have something modeled already?  If not, I would sketch exactly what you have on the bottom left corner, draw a vertical line down the center and do a revolve.
    1. On one of the default planes (it naturally feels like front to me), sketch what you have.  I started with a vertical line from the origin down.  Then I made a semi-circle, center of it coincident with the origin, that has the points horizontal with the origin.  Then I sketched a construction line to indicate the empty space in the ring at the bottom (made sure the vertical line went to a mid-point of that construction line).  Did some dimensioning, offsets, and closed the regions.  I had to add some additional horizontal constraints to make sure the offsets didn't over extend.
    2. I pressed the revolve button in the top left.  This put the entire sketch in the revolve, which was selecting all of the grey areas.  From here I selected the middle line for the axis of revolution.
    Is this what you were looking for?
    Jake Ramsley
  • jakeramsley
    Jake Ramsley
  • CodyH
    Wow, thanks to both of you!
    Neil, that's pretty much exactly what I was trying to build, except maybe the fillet on the base. However, now that you did that I may stick with it! Thank you!
    Jake, thanks for the fantastic tutorial. I'll get started on it. I would say the bottom model looks the closest. The ONLY change would be the addition of a solid base of 3 mm like the rest of the walls. So could we only select the top face when creating the shell? Would that leave the bottom alone while still giving all of the walls a 3 mm thickness? Now I feel a little silly that I didn't think to draw the lines for the base and THEN do the revolve like I did to create the hemisphere. My brain was stuck on thinking of it as separate parts.
  • daniel_chow
    daniel_chow Member Posts: 108 ✭✭✭
    edited January 2016
    Hello Cody,
    To answer your question, you could draw a sketch that outlines a vertical cross section of the bowl shape then use it to revolve / extrude it. But this sketch would take more time to build. That said, there is more skills involved and would be good practice:
    Here is how to revolve / extrude the sketch:
    And renders the same shape
  • daniel_chow
    Just realized I screwed up a dimension, here is the correct one:
    If you are just learning this, I would do draw the model using each of the techniques outlined in this thread. It'll be good practice. You can do it all in the same document.
  • jakeramsley
    Yes, you would just select the top face and you'd still have the bottom as a solid with a 3mm offset.
    Hi daniel_chow,
    one cool thing you can do with this is use in this case is diameter dimensions since it is going to be revolved around and the specifications are in diameters.
    1. If you have a construction line as your center line, start a distance dimension by selecting the centerline and the point you want to measure to.
    2. Before placing the dimension, if you move the dimension to the opposite side of the center line it will turn into a diametric dimension.  This way you can specify these values in diameters instead.
    This way you have to do less math and/or (in my opinion) design your sketch in a way that closer resembles design intent.
    Jake Ramsley
  • daniel_chow
    But Jake, I like snapping things together and using constraints. It's strangely satisfying. LOL
    I will try your suggestion when I get home, looking forward to learning something new in OS today!
    Thank you for taking the time to post that!
  • CodyH
    Daniel and Jake,
    Thanks again for more technique and clarification! This is helping A LOT! Obviously I have much learning to do just to cover the basics, but this helps at understanding different concepts of modeling and where to even begin.
  • CodyH
    edited January 2016
    Actually, I do have another follow up question. Now that I have this shape built, what direction would I take for making edits like extruded or raised sections? For instance, I might be adding raised vertical strips on the bowl. They would be roughly 10 mm wide and extrude 2 to 3 mm from the surface, top to bottom of the bowl. For now, I'm having a hard time piecing together tutorials since I don't come from a CAD background. It would be great to view a webinar or full tutorial building a common object from scratch that incorporates a wide array of tools. I found a few webinars on youtube that I'll look over.Thanks again!
  • jakeramsley
    cody_howe said:
    Actually, I do have another follow up question. Now that I have this shape built, what direction would I take for making edits like extruded or raised sections? For instance, I might be adding raised vertical strips on the bowl. They would be roughly 10 mm wide and extrude 2 to 3 mm from the surface, top to bottom of the bowl. For now, I'm having a hard time piecing together tutorials since I don't come from a CAD background. It would be great to view a webinar or full tutorial building something from scratch that incorporates a wide array of tools. Thanks again!
    Can you draw it, I'm not exactly following what you want.  Normally, what I would suggest is to start a sketch on the top of the bowl and draw your 10mm wide profile and dimension it to be 2/3mm from the edge.  From here you can do an extrude up to a surface and choose the interior or exterior of the bowl.  But I am not sure how similar that is to what you are trying to do.
    Jake Ramsley
  • daniel_chow
    I'm not sure what you meant either. But working off what Jake said, you can do pretty much anything you want by starting a new sketch. Jake is suggesting that you start a new sketch at the top edge of the bowl, I read your post as you wanting raised sections so I made a wild guess at what you're after.
    This is the process of creating a raised section as a new sketch:
    Step 1: If the raised section is reaching the bottom of the bowl, get the vertical dimension of the bowl shape
    Step 2: Start a new sketch as Jake suggested off the top face of the bowl shape
    Step 3: Draw whatever raised pillars / sections you want on the new sketch
    Step 4: Extrude it, select the sketch entities, add the dimension to reach the bottom of the bowl, reverse the direction, add it to the existing part
    Step 6: You can use this techique to make all kinds of raised planes / edges. This was made in about 15 seconds using the same sketch.
    And when you learn how to make a plane at a point / location of your choosing, then you can start a sketch at that plane and draw / add basically whatever you want.
  • CodyH
    edited January 2016
    Jake, I included an update to the original sketch to illustrate what I'm talking about. It's the shaded part.
    Daniel, Thank you for the reply, however, I can't view the images. I wonder what could be the problem since everything else in the thread is displaying fine. Hopefully it gets fixed since I'm really curious to see your tutorial.
    As for drawing planes, I'm still learning how to do that. I haven't been able to find a tutorial specifically teaching this. As you can tell, I'm very novice at this, but this thread is helping quite a bit.
    Thanks again!
  • jakeramsley
    cody_howe,
    To make the strip, I would probably leverage the profile sketch you have already done.  If you sketch the profile of the strip on the top and sweep it, with a little manipulation can get it to work.
    1. Sketch on the top of the top and draw two lines that are coincident with the edge.
    2. Draw two lines that are coincident with the edge of the cylinder.  Make sketch 1 visible and make the two line symmetric about one of the lines in sketch 1.  You can use either the arc or one of the horizontal lines.  Note: while it looks like a rectangle, the edges are actually arcs that are concentric with the edge of the bowl.
    3. Start a sweep, choose the closed profile and sweep along the arc from sketch 1.  The termination of the sweep will be incorrect, even if the arc length is truncated so make sure the sweep is 'New' instead of 'Add'
    4. To fix the termination, start a 'Replace face' and select the end of the sweep.  Replace that face with either the interior or exterior of the bottom of the bowl. This will move the end of the face to either touch the interior or exterior of the bowl.  I chose the interior.
    5. Boolean the parts together to become one part.
    1.png 180.7K
    2.png 274.7K
    3.png 262.9K
    4.png 295.9K
    5.png 180.8K
    Jake Ramsley
  • CodyH
    Since the arc on my model cuts off at the cylinder I wasn't able to follow your directions and sweep it all the way through. Maybe the other issue is I also wasn't able to draw two lines coincident with the cylinder. I'm still having trouble with planes when it's not allowing me to select particular parts of the model. The strip cuts off where the arc meets the cylinder and thus leaves a small gap due to the depth of the strip. As a workaround I simply extruded the strip to the face of the cylinder. I know it's not the proper way since it doesn't continue the same geometry, but since it's such a small gap I figured it could be tolerated for this project. However, I do want to learn how to do it properly! I'm sure there's an easy way to extend the arc to the center axis. I suppose it should have been left alone and then I wouldn't be in this dilemma :P
