can you rotate text
gideonwaldner
Member Posts: 32 EDU
I want to rotate the text in onshape
gideon waldner
@gideon_waldner722 , Yes we can rotate text in Onshape sketch. You have to delete horizontal constraint in text and give dimension to one point after that you can rotate text. Kindly refer below video for more detail.
5 -
Around a cylinder? No, sorry. Please use the feedback tool to request it as an enhancement.Senior Director, Technical Services, EMEA0
No i want the d to be on top so it it spells dewalt from the top to the bottom like this one
gideon waldner0 -
@gideon_waldner722 - you really need to work on being more descriptive in your posts!
Click "show constraints" in the sketch dialog and delete the horizontal constraint shown on the textbox. You may have to fix one corner of the rectangle but then you'll be able to rotate it, and add a vertical constraint afterwards.Senior Director, Technical Services, EMEA0 -
5 -
